Last week I attempted to install the PSoC creator software. However, the first installation failed and every subsequent attempt gets stuck at the same spot. When I try to remove the corrupted installation files, it says that the PSoC creator isn't currently installed, which is correct, but I need a way to reverse whatever changes were made during the initial attempt and do a full reinstallation. Has anyone run into this issue before?
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Please refer this KBA: Troubleshooting PSoC® Creator™ Issues - KBA217546
If does not resolve your issue, please share error screen shot of where it gets stuck.
GeonaP_26
