PSoC™ Creator & Designer Forum Discussions
PaBa_4552536
5 sign-ins 5 replies posted Welcome!
Hi -
This (now locked) thread: Access crypto_core (ECC) from PSoC Creator says
I have passed the query to the internal software team to make the Crypto Core APIs available as part of the PSoC Creator PDL releases. Thank you for your interest in Cypress Products.
Dheeraj
Are there any updates on this?  I want to do some Crypto operations (like SHA) in "chunks" (not as one block), and the only way to do that seems to be via the Direct Crypto Core API, which isn't available in PSoC Creator's PDL.
DheerajK_81
No. Direct Crypto Core access is still not available in the latest 3.1.3 PDL release. We recommend moving to ModusToolbox for developing your applications targetting PSoC6 devices. The psoc6pdl library offered with ModusToolbox has both the Client-Server and Direct Crypto Access models available.
I will update the thread when this support is added in the PSoC Creator PDL release. However, there is no priority at the moment to have this included in PSoC Creator. If this request is to change anytime in the near future I will let you know.
Dheeraj
DheerajK_81
Dheeraj
Len_CONSULTRON
Level 9
Level 9
500 solutions authored 1000 replies posted 750 replies posted
PaBa,
Maybe I'm missing your intent.
In PSoC Creator, select the project then Right-click and select "Build Settings..."
You should get the "Build Settings" window.   Now select "Peripheral Driver Library".  There is a PDL crypto base library selection that should include the code to use the crypto functions.
Len
Len
