PSoC Creator Clean Build Program Cycle
PeSw_2288441
Hi
Is there a setting to force PSoC Creator4.2 to always perform a clean and build before programming?
I have found if I modify a file and program the device, without doing a "Clean and Build", the modified code is not always used.
It would seem, if a file other than main.c is modified then the old binary file is programmed in the device as the compiler doesn't generate a new binary file.
Pete
Yugandhar
When we want to modify the code in component’s generated source file,  steps has to be followed which was explained in this Link.
If we add any user defined library files then we have to do "clean and build" before programming.
P Yugandhar.
Yugandhar
Hello Pete,
Can you please check with other example project.
Please tell the complete version of PSoC Creator.
P Yugandhar.
Thanks for responding. Sorry it took so long to get back to you.
I have tried to replicate the issue on a simple sample project with no success.
I will keep trying to locate what causes the issue in my project and post here when/if I have more specific information.
Pete
Yugandhar
P Yugandhar.
