Please try these options to debug installation issues -
- Run the Installation file as an administrator (right-click the file and select Run as administrator).
- Check System Configuration
- Refer to the Release Note to verify that your system configuration meets the PSoC Creator installation requirements. You can find the Release note from PSoC Creator Landing Page, Documentation tab [Check Installation >Operating System section] or PSoC Creator Release Notes Archive.
- Reinstall PSoC Creator with the help of Registry Repair Application
Try reinstalling the PSoC Creator/Programmer after cleaning up registry entries by using this tool. CyInstaller installs several MSI files; each MSI file has its own unique registry entry. Before installing the MSI package, Windows checks whether a registry entry related to the MSI being installed is already available. If available, the installer skips the related step. Therefore, any incorrect registry entry can lead to installation issues. - Check whether your Anti-virus is causing this issue
Some antivirus software remove certain EXE files from PSoC Creator installation due to false detection. Do the following in such cases:- Disable the Antivirus in your system.
- Reinstall PSoC Creator.
- Enable the antivirus software again after PSoC Creator installation is completed.
Also, did you get any error message while uninstalling PSoC Creator 4.2?
-Sayani.
