A few days ago, PSoC Creator 4.1 closed without warning. When I tried opening it again, an installation window appeared with the following text: "Please wait while Windows configures PSoC Creator". But it ends in error: "Error writing to file: C:\Program Giles (x86)\Cypress\PSoC Creator\4.2\PSoC Creator\bin\psoc_creator.exe. Verify that you have access to that directory." Then I have to cancel the "installation" and I can't open PSoC Creator.
I changed the permissions of that file so every application has total control, and that seemed to solve the issue.
Then I installed PSoC Creator 4.2 to use my kit 149, but the same thing happens when I use some features of the CapSense block (the only one I'm using right now). It closes and I can't open it again. Changing permissions does not solve the issue now.
What is failing? What can I do?
Andrés
