Using PSOC Creator 4.4 on a win7 x64 system I get the following error message:
after clean and build I get:
prj.M0120:Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
I implemented several projects before and everything worked well. Now with this project I get this message. I switched back to an old project, here the make process is OK. The problem seems related to the project setup.
Please help to get my project build working
PSoC Creator & Designer Software
I found the problem. I renamed a method using FIND/RENAME in all files... obviously all occurrences had been renamed but the method itself in c fie stay with the old name. Thus there was an correct entry in h file but the corresponding method in c file was missing!
What I found is that switching to "OUTPUT" helps a lot.... Just search for "output" at the bottom of the window
