I used Psoc creator 4.3 for a log time with out getting such a issue. Since some days the creator freezes when trying to start debug. I updated to version 4.4 but the issue still exists. Psoc creator freezes for about 120 sec and then continue, windows give a sound. Today each debug start suffer from this delay.
WIN 10, MINIProg4, only 20GB free SSD space left.
What can I do to get rid of this pause?
PSoC Creator & Designer Software
RuGl,
I'm not aware of a debugger log file.
You said you were using a MiniProg4. The next step is to determine if the slowness issue is linked to the MiniProg4 or in general with the Creator 4.3 or higher.
I'm using Creator 4.3 and have no debugging slowness issue except for those I know will slow the debugger response like large memory monitor windows.
Experiment #1 - Try a different programmer debugger
Do you have one of the Cypress kits/eval boards? If so, it has a KitProgx programmer debugger. If the debugging slowness is still present, we'd have to look at possibly reinstalling Creator or installing an earlier version of Creator. If debugging is much faster, it is a problem with the MiniProg4 HW or it's configuration in Creator.
Experiment #2 - Use a known working example program
The example programs for Infineon use minimal debugger settings. This will help to determine if something went 'wonky' with the project's settings.
