Hi all
I created a new virtual machine with Windows 10 and moved existing PSOC Creator projects to shared folder with host Ubuntu OS.
I'm getting strange exception (shown bellow) if I run projects and open one of source files from shared folder. But if I run it from virtual machine's local disk everything is OK. I also ran a clean and rebuild command but the problem still remains.
What could be the problem?
Simon
Reason for error: This happens when you run PSoC Creator on a virtual machine and access source files from a shared folder. There is a known issue with a third-party tool that is used to support the Semantic Parsing features. For more information, refer to the bug report for that tool (http://llvm.org/bugs/show_bug.cgi?id=21143).
Workaround: Disable Semantic Parsing using the Tools > Options > Semantic Parsing menu item. Please note that this requires a PSoC Creator restart.
