I Have a critical error which have popped up and I cant get rid of it. I have a project for a PSOC 4200 BLE MCU, where a use the upgradableStack project. I have added a new application project to this and I am getting this error:
Error: prj.M0266:
Shared code exported by instance CyBle of component BLE_v3_66 is not identical to code expected by instance CyBle of component BLE_v3_66.
(App=psoc_creator)
This currently prevents us from exporting the project to eclipse, for further development at a critical stage in the project.
Any help is much appreciated !
regards,
Martin
PSoC Creator & Designer Software
- PSoC 4 MCU
There was a difference between the CyBle.cycsa file in the stack project and application project. Rebuilding (clean and build all projects ) did not help.
I had to manually delete the files from Generated_Source folder for both projects and then rebuild. Now they agree on the checksum .
I use PSoC Creator version 4.2. If it hasn't been changed in 4.3 or 4.4. Please ensure that the content of Generated_Source folder is deleted when performing the Clean action.
br,
Martin
Hello Martin,
This thread had the same issue. Please check if it helps 🙂
Dheeraj
br,
Martin
