02:57 PM
Jan 11, 2009
02:57 PM
After simulating the design, i go to BUILD and GENERATE PROJECT. Here a suitable device is selected and OK is pressed.An error called PROJECT GENERATION ERROR is being shown.Please advice to overcome this problem.
05:21 AM
Apr 07, 2009
05:21 AM
I think you are beginning with PSoC. I will suggest you to follow the Quick Start Guide that comes along with the PSoC Kit that you have purchased for the initial few times. Wish you all the best!
Apr 07, 2009
05:56 AM
Apr 07, 2009
05:56 AM
It seems that you are using System Level Design. When it gives the compilation error it gives information regarding why the compilation has been failed. I request you to provide that information also try updating to the PSoC Designer 5.0 SP4 which is the latest version of PSoC Designer till date.
Pushek
Pushek
