Using PSOC 6, error is asking to update PDL library to latest version.
It is and has been updated and reinstalled. Still error.
Regards, Dana.
Dana,
Leo is correct.
You can use his method to make sure the PDL library version is up to date or ...
Go to "Project/Build Settings .../<projname>/Peripheral Driver Library"
Find the 3.1.5 version of the PDL root location using the "..." button then select "OK".
Hi @ETRO_SSN583
Can you please share the error log shown in the console as a text file shown in PSoC Creator?
Thanks and Regards
Leo
Regards, Dana.
Dana,
I was able to build your project with no errors or warnings using Creator 4.4.
Here is the Component versions from my build:
Do you get the same versions?
I have the same components and versions.
Regards, Dana.
Dana,
Interesting. As I indicated, with those versions, I have no build complaints. Your system does complain.
Dana,
Leo is correct.
Dana,
Is this issue considered "Solved" based on Leo's or my suggestions?
Hi @ETRO_SSN583
Please click on the Tools tab, navigate to Options and ensure that the path for the latest PDL library location is set as shown.
After setting the path, click on Apply and select OK. Try building the project after this configuration.
Thanks and Regards,
Leo
