ViDv_264506
Level 5
Level 5
50 sign-ins 25 sign-ins 5 solutions authored
the updated ARM compiler Keil MDK4.74 version can program devicel like.
   CY8C4013SXI-411, CY8C4013LQI-411, CY8C4013SXI-400, CY8C4013SXI-410,
   CY8C4014LQI-421, CY8C4014LQI-412, CY8C4014SXI-411, CY8C4014SXI-421,
   CY8C4014LQI-422, CY8C4014LQI-SLT1, and CY8C4014LQI-SLT2.
any technical data, datasheets etc. available?
Viktor
ETRO_SSN583
Level 9
Level 9
Searches only show qual reports. You might consider filing a CASE to see if
you can get pre-release datasheet -
To file a case -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
You must be registered on cypress.com to file cases.
Regards, Dana.
ViDv_264506
Level 5
Level 5
it is the smallest part of the PSoC4. Read the last published RoadMap.
Viktor
Bob_Marlowe
Level 10
Level 10
Since the PSoC4 CY8C40-family still has got CapSense capabilities as all the PSoC4s have got, these devices will probably aim at this market. Wasn't Cypress world-leader in capacitive touch-devices.
Looks as if designed for low-cost big-volume production chips.
Bob
These are the new PSOC4 run at 16Mhz with 16k flash and 2k ram . Look at the product road map
http://www.cypress.com/?docID=47209
I'm looking forward to the QFN-16 and SOIC-8 parts that take very litle board space
RobynW
5 likes given First comment on blog 10 likes received
As you've seen, Cypress is continuing our development of new PSoC 4 families.  Keep your ears tuned in the next couple of weeks for more details about the PSoC 40xx product line.
It looks like some of you are using Keil's IDE.  Have you been using PSoC Creator 3.0's export to Keil function?  How has it been working for you?
-Robyn
