I want t run 2 debug sessions on same computer.
Though I can run 2 instances of Creator, I can only connect to a single Mini-Prog 3 device.
Is there a way to make this wok on a single PC or do I need separate computers for each MiniProg?
Seems like it should, each Miniprog negotiates its own USB session.
Then when you select Debug connection I would think you choose which Miniprog
to use ?
Quick test with simple projects should determine if this is possible.
Regards, Dana.
Thanks Dana,
I managed to get it running ok in the end by right clicking the Creator on task bar and running a second instance. I then found I needed to unplug the first mini-prog that was already connected and plug in the second one and run a session, then I could plug in the first one and run both sessions at once. After I had both miniprogs running then I could debug both sessions no issue.
That's pretty cool, I will store this one in the back of my empty head.
Thanks for taking the time to do the update.
Regards, Dana.
You can select different target from
Debug -> Select Debug Target
Jobin
