It looks like this is the place for this kind of comment...
- Easier switching between normal and bootloadable project settings.
I am working with a bootloadable project, but attaching the debugger is a pain, so I switch back to normal for easier debugging. This means I need to delete the Bootloadable component and comment out any code the refers to it, and put it back later. Not the end of the world, but having a way to do this with a single project setting would be nice.
- Multiple cydwr files, only one active at a time
I sometimes want to run code on my hardware then on dev board hardware for certain types of testing. The only way I know to do this is create two projects that share the same code, but have different cydwr files, or modify the file each time. I suppose I could keep copies in the background and rename the one I want to use... It seems not too difficult to have more than one file in the project, but only one "Active."
