ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
One of the most common errors users make is to not issue a module_x_start()
command. Causes lots of forum posts and Cypress employee time lost.
Maybe a check on this and a warning issued ?
Look at other common errors as well ? GPIO settings inconsistant with code use ........
If this takes a lot of build time, eg. additional scan of code base, make an option
in the compiler properties.....
Regards, Dana.
