03:28 AM
Jun 24, 2009
03:28 AM
When i use cube ice and 21x34 pod practice modify IO port,
Pod only connect P17 to voltage meter, no other external component.
the code make me confuse. (PS. Designer 5.0)
PRT0GS &= ~0x08; //disconnect from global bus
PRT0DM2 |= 0x08;
PRT0DM1 &= ~0X08; //DM[2:0]=100, Slow strong high, high-z low
PRT0DM0 &= ~0x08;
PRT0DR &= ~0x08;
PRT3GS &= ~0x02; //disconnect from global bus
PRT3DM2 |= 0x02;
PRT3DM1 &= ~0x02; //DM[2:0]=100, Slow strong high, high-z low
PRT3DM0 &= ~0x02;
PRT3DR |= 0x02;
P17 is modified to low normally,
then modify P31 ,
P17 become high.....
Can any one tell me why ? please.
I forget the P17 and P31 both connect to analog bus....
Forget my stupidity.
PRT0DM2 |= 0x08;
PRT0DM0 &= ~0x08;
PRT0DR &= ~0x08;
PRT3DM2 |= 0x02;
PRT3DM0 &= ~0x02;
PRT3DR |= 0x02;
then modify P31 ,
05:08 AM
Jun 29, 2009
05:08 AM
I do not know what is complete application and in which context you are doing it. But I can explain what these lines of code are doing.
PRT0DM2 |= 0x08;
PRT0DM0 &= ~0x08;
PRT0DR &= ~0x08;
It will disconnect pin P0[3] from global bus if it was connected earlier. Then it will change drive mode for P0[3] to open drain drive high. Then P0[3] is turned to High-Z output by writing a '0' to its data register.
PRT3DM2 |= 0x02;
PRT3DM0 &= ~0x02;
PRT3DR |= 0x02;
It will disconnect pin P3[1] from global bus if it was connected earlier. Then it will change drive mode for P3[1] to open drain drive high. Then P3[1] is turned to High output by writing a '1' to its data register.
Sachin Gupta
PRT0DM2 |= 0x08;
PRT0DM0 &= ~0x08;
PRT0DR &= ~0x08;
PRT3DM2 |= 0x02;
PRT3DM0 &= ~0x02;
PRT3DR |= 0x02;
Sachin Gupta
