odissey1
Level 9
Level 9
I created a custom symbol by modifying Cypress stock component. Now it shows original document author "meh" in the Doc.CreatedBy field section. So far I couldn't find a way to clear or modify this field.
Q: Is there any way to remove/modify this field or a new symbol has to be created from scratch? (And do the same for the other 20+ custom symbols that were derived from this one!).
/odissey1
VenkataD_41
Please tell us what do you mean by stock component? Could you please send us the project you are using?
Ganesh
gani,
I used Cypress some off-chip component (resistor?) as a stub to create my Annotation library symbols:
Annotation library for CY8CKIT-059 Prototyping Kit
I decided to upgrade the library and to clean it up, starting from a clean component (this way a reference to "meh" is also gone). At this point I am already half-way through, so my question became obsolete.
/odissey1
