PSoC™ Creator & Designer
EsFr_4600111
25 sign-ins 10 replies posted 10 questions asked
Using Psoc creater 4.2 for BLE development.
I have been going through some of the turtorials, but some of them use the logic components (AND,OR NOT etc.) But theese components are not avilble in my setup, how can i enable theese ?
Rakshith
Moderator 1000 replies posted 750 replies posted 500 replies posted
Hi EsFr_4600111,
Can you please share the screenshots of the above steps? I have shared the screenshots of my PC below for your reference -
Also, can you please try the following -
1. Click on Components tab in Workspace Explorer.
2. Right click on your project and click on Import Component.
3. Select Import from project/library.
4. Select CyPrimitives in the drop down and then select and component as the source component as shown. Click on OK.
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi EsFr_4600111​,
It seems like your components are not updated. Can you please update your components list by these steps -
1. Tools-->Find New Components and Find New Devices to upgrade the Creator to latest status.
2. Follow the steps mentioned in this KBA - Updating PSoC Creator Components
Hope this helps,
Rakshith M B
Thanks and Regards,
Rakshith M B
EsFr_4600111
Hi Rakshith
This did'nt solve my issue. 😞
Still can't see the eg Not function in Digital->  Logic folder
Br
Esben
Rakshith
Hi EsFr_4600111,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
