Hi, Supporters
I saw an article that UART sense tuner is not available in Miniprog3.
Can Miniprog4 use a sense tuner with UART?
I use a PSoC 4000S for the MCU.
PSoC Creator & Designer Software
Hi @Newa,
Yes, sense tuner can be communicated using UART or I2C when Miniprog4 is used.
Go to tools->tuner communication setup. Both UART and I2C options will be displayed in the Ports window in the tuner communication setup window. You can select UART and configure the parameters in the Port configuration at the right.
Nikhil
Hi @Newa,
Nikhil
