AkAb_1248121
First like given
The toolbar that was there last week is gone. Once I deleted the software and reinstalled it, it didn't improve. (Deleted all Cypress folders)
Currently, I cannot compile or write.
OS: Windows10Pro
This issue has been resolved.
1. Uninstall PSoC_Designer.
2. Delete the C: \ Users \ *** \ AppData \ Roaming \ Cypress_Semiconductor folder.
3. Install PSoC_Designer again.
Finally the ToolBar is displayed.
Thank you for the advice.
Google 翻訳で開く
フィードバック
ウェブ検索結果
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Can you kindly press the "Alt" key. This should make the menu bar visible. Then press the "T" and then "C" key, This should bring up a dialog box. Enable the "Menu Bar". This should display the Menu Bar permanently. Enable the toolbars whichever you want active.
Hope this should resolve our issue. Do kindly let us know.
Sampath Selvaraj
Thank you for your reply.
I tried the ALT key but the menu bar didn't appear. Any other points to check?
Google 翻訳で開く
フィードバック
ウェブ検索結果
