I installed the USBSerialSDKSetup.exe and have the Eclipse, usb drivers working fine. But I don' see USB-Serial configuration utility anywhere? Is that still needed for the latest version of the SDK?
If yes, where can I find it?
I only see mention to download the User Guide on the web site.
rgrds
Hello.
I've not tried this but, if you read this thread:
Solved: Location of USB-Serial configuration utility - Infineon Developer Community
the utility is part of the SDK installation. BTW, those embedded links don't work for me.
Assuming you fetched the SDK from here:
USB-Serial Software Development Kit - Infineon Technologies
based on previous thread, you already have the configuration utility installed. And, from Infineon SDK page:
"The Software Development Kit (SDK) comes with configuration tool (Windows only), drivers (Windows only), libraries and application examples. "
My $0.02 worth.
Thanks for your fast response and help BiBi.
I just reinstalled everything this morning and it seems that i have everything there now. Probably I messed up when installing for the first time.
Now I can also see the OpenOCD Jtag options on the debugger.
rgrds
marcos
