Ladies and gentlemen!
I needed the PSoC (CY8c5888LTI-LP097) for a school project, but whenever I connect it to my PC, Windows tells me that it cannot find any drivers and does not read the device. Is there a way to get the drivers or could you help me with this problem?
Thanks in advance!
Ekta,
I believe Nils is using a CY8CKIT-059. It uses the Kitprog and not the KitProg2.
Therefore I believe ""C:\Program Files (x86)\Cypress\Programmer\drivers\KitProg\KitProgUSBUART.inf" should be used instead.
Hello @Nils1
Can you try following the steps below to bind the correct driver to the PSoC 5LP device:
Please follow these steps to manually bind the driver software of KitProg from the PSoC Programmer installation directory.
1. Right click on 'KitProg' and select 'Update Driver Software'.
2. Select 'Browse my computer for driver software'.
3. Select 'Let me pick from a list of device drivers on my computer'.
4. Click 'Next'.
5. Click on 'Have Disk'. Please ensure that you do not miss this step.
6. Browse and select the following file - C:\Program Files (x86)\Cypress\Programmer\drivers\KitProg2\KitProg2UART.inf
In case the device is still not recognized kindly let us know.
Thanks and Regards,
Ekta
Hello Ekta
Thank you for the fast feedback.
I went through your steps and once I select the path "C:\Program Files (x86)\Cypress\Programmer\drivers\KitProg2\KitProg2UART.inf" and then click "OK" the window closes and reopens and want me to choose a path again. I also looked for the driver on the left but couldn't find it either.
Unfortunately, the PC still does not recognize the PSoC.
Thanks again for the quick help and regards
Nils
Ekta,
Hi Len,
Thanks for correcting me. You are correct PSoC 5 uses kitprog. @Nils1 can you please try following the same steps but using the "C:\Program Files (x86)\Cypress\Programmer\drivers\KitProg\KitProgUSBUART.inf" istead?
Let us know if you face any issues after that.
Best Regards
Ekta
