I've installed PSoC Creator 1.0 on two PC's. Both times I've run into trouble with building my first project. The error generated in Creator is something to do with the Tools.ini missing. This time I'd thought I would post the to solution to my problem for any others that could use it.
Solution:
  1. Locate the file  "Cypress Install Folder \ PSoC Creator \ 1.0 \ PSoC Creator \ import \ keil \ pk51 \ 8.16 \ _TOOLS.INI"
  2.
  3. Copy and rename "_TOOLS.INI" to "TOOLS.INI". Keep it in the existing folder.
  4.
  5. Register Keil. Open PSoC Creator > Help > Register > Keil > Get LIC via Internet. Once you have the LIC number enter it into step 2 and click Add LIC.
  6.
I hope this will be usefull to someone.
sharing your results with the forum is great! Although I did not run into the same issue, if it happened to you twice there will be others.
Thanks for sharing.
mattl_01
100 replies posted 50 replies posted 25 replies posted
See this KB article if you run into situations which are not handled by this suggestion.
http://www.cypress.com/?id=4&rID=58944
