Hi All
As a result of not always working in the Creator IDE, say Droidedit while on the road, the CYDEV_CHIP_JTAG_ID is not always accessible in cyfitter.h
Is there a reference or include file with all PSoC parts and corresponding CYDEV_CHIP_JTAG_ID's?
Many Thanks
Greg
Hi Greg,
Please find it here: C:\Program Files (x86)\Cypress\Programmer\Devices
JOBIN GT
Hi Greg,
JOBIN GT
Hi Jobin
Thanks for the details. Would you know if the second JTAG id listed in the xxxx.dat files should be used / is needed for compiler directives such as CYDEV_CHIP_JTAG_ID?
#if (CYDEV_CHIP_JTAG_ID == 0x4C81193)
// My code
#endif
For example in CY8C4xxx.dat the following line has two entries:
2,CY8C4245AXI-483, CY8C4245AXI-483, 44, 32768, 3, 04_C8_11_93, 04_C8_12_93, v33
PSoC Creator recognises the first entry when creating a project with the above PSoC device.
My aim is to create a header file similar to the attached, to reference the PSoC4 family.
Many thanks
Greg
Check the first two bytes i.e.04_C8 and mask the remaining one's.
The first two bytes corresponds to the Silicon ID ,third byte corresponds to silicon revision.
