I use PSoC version 4.2 and the example of capsense V5.0 work normally, I want to use capsense v7.0, but it always report an error. Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
Is my PSoC version inappropriate?
What is the improvement of v7.0 compared with V5.0?
CapSense V7.0 is supported in PSoC Creator 4.2. After updating the component, can you try restarting PSoC Creator so that the right dependencies are fetched?
Hari
Hari
