 I saw SPI Master, SPI Slave, EZI2C Slave components; however, I could not find I2C master.   Has any one created one for reading multiple I2C slave devices, such as I2C EEPROM, I2C Temp Sensor, etc.
HeLi_263931
Level 8
Level 8
There is an I2C master / Multi-Master / Slave component available: http://www3.cypress.com/?rID=51969
Bob_Marlowe
Level 10
Level 10
Depending on WHICH PSoC you use there are several different modules to use:
In PSoC 1 there are a I2Cm and an I2CHW which will even run as multi-master
In PSoC3 and 5 there are 3 different configurations for I2C-masters.
Happy coding
Bob
 I am looking for I2C master component for PSoC5LP?  Can you please point to the right component and link?  Thx
Bob_Marlowe
Level 10
Level 10
Despite the fact that there is an example-project fpr PSoC5 LP named DelSig_I2Cm when starting a new project with Designer 2.2 there is the component catalog that shows *all* components. There you'll find the required I2C-master components.
Bob
