Hi all,
I have PSocEval USB CY3214 board and the mcu included is CY8C24094-24AXI, I downloaded PSoC designer 5.1 and programmer 3.1. When I try to make a new project with the Designer, I couldn't found the chip reference above. I just found CY8C247xx-XXX, CY8C248xx-XXX, etc. The reason why I dont use the CDs with the kit is because the version I got for the designer was v4 (~2007) and for that version imagecraf compiler is not yet free. I'm asking how can I do to use my board (PSocEval USB CY3214 board and the mcu included is CY8C24094-24AXI) with the last version of the designer ? Note that the programmer works fine for me ( I used it with some old examples that I managed to open them with the version 5 of the designer).
Thanks for help.
our development team for evaluation kits has been contacted and will provide an answer shortly
Robert
could you please check this site for up to date projects.
http://www.cypress.com/?rID=37815
I would not know about a reason why this would not work if the latest projects are used with the latest version of Designer.
Robert
