ETRO_SSN583
Level 9
Level 9
Hi, this library of TTL components, how do I import into tool such that it
looks like a "normal" tool library ? So that all the components are a tab
and I do not have to set dependencies each time I pull one onto canvas ?
20 New Simple Teaching Components
I keep trying various ways, none seem to work except one at a time set up
dependencies.
Regards, Dana.
Hi Dana,
You can make use of Default Dependency option available in PSoC Creator as described in this video:
https://www.cypress.com/video-library/PSoC-Software/psoc-creator-tutorial-adding-library-dependency/...
I hope that can be somehow more helpful in your requirement.
Ankita
odissey1
Level 9
Level 9
Dana,
Not clear what the problem is. I see Simple Components library OK. Installed into Project->Dependencies->User dependencies. This is not "permanent dependency", and need to be added to each new project.
/odissey1
Thats what I found and am trying to avoid. There must be a way of
creating semi permanent library, and only have to reinstall each new
new release of Creator.
Regards, Dana.
Hi Dana,
Ankita
That worked great, video, now entire library shows up.
Regards and thanks, Dana.
