05:30 AM
Jan 09, 2009
05:30 AM
I have been out of the PSoC loop for a while, and want to get started with it again.
Unfortunately I have run into a problem.
I have a PSoC ICE-4000 with USB-4000 usb adapter, which all worked perfectly under designer 4.2
However I now installed (on a new PC) Designer 5.0, which basically seems to refuse to work with anything else than a ICE-CUBE.
After some searching, I have found and installed the PSoC Progammer utility, which enables me to program a PSoC using the ICE-4000. This also works inside Designer 5.0, but I still am unable to select, configure and use the ICE functionality.
Does anyone know how I can get my ICE-4000 up and running under Designer 5.0 ?
Thanks in advance.
Robin Stevenhagen
Thanks in advance.
Robin Stevenhagen
07:18 AM
Jan 12, 2009
07:18 AM
Hello Robin,
Unfortunately, PSD5.0 does not support debugging using the ICE-4000. I would suggest you to upgrade the ICE to the latest CY3215 or work with PSD4.2.
Ganesh
Ganesh
