I can view the ADC conversion of thermistor voltage in oscilloscope, but LCD is not displaying any text and numbers.
Would be easierfor us to help you when you
Providel ink to datasheet of LCD
Attach your project using Creator-> File -> Create workspace bundle
Bob
The Character LCD component is made fr a Hitachi 44780 LCD driver and uses only 4 data lines. I would suggest you to use a I2C driven LCD module or a 44780 compatible one.
Bob
Your project works for me.
I did not install resistors. LCD PMC16023CP1(5v) Vcc=5V
board: CY8CKIT-059:
capacitors removed: P0.2(C12) P0.3(C13) P0.4 (C9) P3.2(C7) P5.4(C4)
Those two picture seem to be identical, may be I need to see it more carefully..
Anyway in the Kit Guide of CY8CKIT-059
So I think that using following pins for fast signals is not a good idea
P0_2
P0_3
P0_4
P3_2
So how about changing following signals?
LCDPort[6:0]
P2[6:0] -> P1[6:0]
P3_2 -> P3_5 (P3[5])
moto
On pin3, tension is required for Contrast adjustment. is it present?
I even checked the continuity of the pins from PSOC chip to LCD board. Connections are good, also I downloaded custom character LCD example and tried that one, it is not working. Do I need to install 10K resistors? I think it should work even without resistors, is there a problem with the hardware on the psoc board?
Yes contrast adjustment, I connected the resistors on Pin 3, without them the boxes are not visible.
