LePr_1339861
First like given 5 sign-ins Welcome!
Following CE220263, I believe I have set up everything correctly. I just want to do Cy_GPIO_Write or Cy_GPIO_Set/Cy_GPIO_Clr. The code builds with no errors or warnings, but the pins do not move. Is there any instruction or sample for this simple implementation? I am under the gun to deliver.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I assume that you are using CY8CKIT-062-BLE for that CE, correct?
With CY8CKIT-062-BLE, according to the Kit Revision(s) there are some limitations/requirements.
https://www.cypress.com/documentation/development-kitsboards/psoc-6-ble-pioneer-kit-cy8ckit-062-ble
You can check the PDL version from the PSoC Creator Menu Project > Build Settings...
In the Build Settings Dialog, select Peripheral Driver Library
Then you can see what PDL version is set for your environment. (My case it's 3.1.2)
You can change the default version from the Menu Tools > Options
or just select "Custom" and specify an appropriate PDL version installed in your system.
To download other version(s) of PDL, go to
https://www.cypress.com/design-guides/peripheral-driver-library-pdl-psoc-creator
Just in case, if I'm totally missing the point. I'm sorry.
moto
MotooTanaka
Level 9
Level 9
moto
LePr_1339861
Thanks much, your info helps me going forward. I also found a couple issues in my code. I now am able to control the pins fine.
