11:47 AM
Oct 12, 2016
11:47 AM
Hi, how can I "disgray" out a function from a library? I'm using the same library in two different projects, one is an example code and the other is mine. In the example, the function works but in my code the function doesn't works and I need it. The two blocks are exactly the same. How can I do it?
11:43 PM
Oct 12, 2016
11:43 PM
Depending on the configuration of the component some parts of the API are available or not. So you need to look there. (In your case you need to enable the injection channel)
11:51 AM
Oct 12, 2016
11:51 AM
I suppose you are talking about functions in generated code.
Which component and which API function you are talking about? Which device??
Bob
Oct 12, 2016
03:03 PM
Oct 12, 2016
03:03 PM
Yes, it is generated code. I'm trying to use ADC_SAR_SEQ_EnableInjection() on a CY8CKIT-043 (4200M). I've declared the library.
Oct 12, 2016
11:43 PM
Oct 12, 2016
11:43 PM
