Hello, just starting to ramp up on the PSoC creator. I am looking for the "go back" feature--similar to the back arrow in Visual Studio, or Alt-left-arrow in Eclipse. I apologize if this should be obvious.
As you may see, we are not quite familar with Visual Studio or Eclipse.
To go back to a previous position in your sources, use Ctrl - (Control minus).
In Creator 3.2 Help you will find a list of shortcuts for some keys.
Bob
Undo ? Ctrl Z, look in Creator User manual for keyboard shortcuts.
Regards, Dana.
Bob
Zoom In/Out/To [Ctrl] + [+]
or Ctrl + [–]
Adjusts size of the page according to option
From Creator Manual........
Go to Help-> Documentation-> Key board Shortcuts , then you will be able to find all the available shortcuts.
#Go back to previous cursor location in Code Editor. [Ctrl] + [-] (Use [Shift] for reverse direction.)
And the [Ctrl] + [-] can do the same thing as mentioned by danaaknight while in View menu
Alt-left-arrow in Eclipse can do ----- Go to previous / go to next Editor Window
I think there is a similar option in PSoC Creator---
Switch between schematic pages. -------[Ctrl] + [F6] (Use [Shift] for reverse direction.)
Jobin
