PascalS
Level 4
Level 4
25 replies posted 10 replies posted 10 questions asked
I would like to define variables inside a for loop like this:
if(int i = 0;i<10;i++){
    //FOO
Therefore I tried to add Command Line Custom Flags like "-std=gnu11" / "-std=c11":
But it brings me the following error:
"Expected expression before int"
BR
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @PascalS ,
Can you please make sure that the syntax you are using is correct?
You have used "if" instead of "for" which is why you are facing this error.
Can you please make this correction and try the build operation again?
Warm Regards
Alen
AlenAn14
Hi @PascalS ,
Warm Regards
Alen
AlenAn14
Hi @PascalS ,
Glad your query is resolved.
Please feel free to post any queries or issues you may have on Infineon products in the community and we will be happy to help.
Thanks and Regards,
Alen
