Sep 19, 2021
02:09 PM
Sep 19, 2021
02:09 PM
Is it any redy to use windows command line tool making possible simply set/reset one of the pin of kitprog 3 device?
I would like to use it to power up a device I want to access using SWD interface just few milliseconds before starting openocd session...
Thank you in advance
Kris
Labels
PSoC Creator & Designer Software
11:47 PM
Sep 20, 2021
11:47 PM
Thank you,
All the wires are shorter then 5cm. Probably all the modules I got have locked SWD. Finally I reached to the man, who was able to connect same module, and he also said, that he had a problem with one batch of the modules. Thank you for your support.
