ShMi_1495391
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
When launching PSoC Creartor or updating components, the folder are automatically created in the following directories.
C:\Users\username\Documents\PSoC Creator
Is it possible to specify a generation destination?
You can make use of Default Dependency option available in PSoC Creator as described in this video:
https://www.cypress.com/video-library/PSoC-Software/psoc-creator-tutorial-adding-library-dependency/...
I hope that can be somehow more helpful in your requirement.
AnkitaS_51
Please check interaction#16 on this forum thread, it gives a workaround:
User home path problem (bug?)
Thank you.
But, with this method, I have to set it again each time Workspace is created.
Is there a way to reflect this setting in all new Workspaces?
I am sorry to inform but presently there is no option in Creator by default  to change that default path for components.
I see. Thank you.
Thank you very much.
