Hello.
Can anyone help with this:
The code below is where the problem occurs.
uint8 frameBuffer[600][400] __attribute__ ((aligned(),section(".frame_buffer")));
And, It is my "Custom Flags".
-Wl,--section-start=.frame_buffer=0x20000000
Below is my error message.
This error does not occur in Creator v3.3 and i confirmed that it is not related to GCC version.
I don't know why occurs build error in Creator v4.2.
Hello Russel,
When I built your project I was able to reproduce your error. I see the same error message and the output window says that "Flash address outside hex file range".
I removed the linker commands in the build settings and created a custom linker script and added the following line of code inside SECTIONS:
.ram2 0x20000000 (NOLOAD):
*(.ram2)
} >ram
After adding this, the project built successfully. I have attached the linker script below for your reference. Let me know how it goes
Dheeraj
Please find the project attached. I tried the exact same thing and it seems to build successfully in PSoC Creator 4.2. So, I don't think the error might be because of this.
In any case, which kit are you using? Can you share your project so that I can look at various settings?
Please right click on your project > Archive Workspace/Project > Minimal and then share it.
Dheeraj
Hello Russel,
*(.ram2)
} >ram
Dheeraj
Hello ddka.
I solved this problem with your help.
Thank you a lot your helping.
Russellcustom_linker.ld.zip
