How can I open the TopDesign.cysch file to read what is in it?
Thanks for the help.
(sorry the bad english)
        Double click it in Workspace Explore / Source TAB. Isn't it open?
 I've opened it in notepad, it seem like a serialized binary object., you will probably be able to properly read it using any HexEditor
HeLi_263931
Level 8
Level 8
This file is not designed to be human-readable. Open the accompanying project in Creator, and from there open the schematic file.
Or is there any other reason you want to read this files contents?
 I'll try to read using a HexEditor. Thanks for the help.
ps: I need to read this file for my project.
 Can't read with HexEditor too. Any other suggestions? I really need to read this file. Tks
 Can you tell us why you need to read this file? Is that for some kind of version control or system archieve?
ETRO_SSN583
Level 9
Level 9
The file is a schematic gui file. So its a mix of tags, object properties, color,
luminance, vectors, coordinates...........
It is opened and viewed by a tool within creator. If you double click it
in Creator a schematic is displayed and you are permitted to modify
it with the schematic editor and the properties of the module you are
placing.
That is how you open it.
Regards, Dana.
I trying to create a simple program that export the schematic to a simulator, that's why i'm trying to read the file. Reading the file, i can identify the circuit and export it to a simulator.
Many of the files open like xml file, but the TopDesign don't. I'm trying to figure out how to open in a readable way.
HeLi_263931
Level 8
Level 8
        Some observations:
- it is not compressed, since one can read the strings in it
- its unicode / UTF16 (but it hasn't a BOM at the beginning)
- there are many strings which read like class names (e.g. CyDesigner.Common.Db.CyS3DB.CySsModelHeader)
- remember, Creator is a .NET-application
- there are also class field names in the files (e.g. m_compName)
So most likely this is serialized object structure, generated directly from the internal representation of the schematic
So you should try to read it with .NET (or Mono). I don't know enough about .NET to tell whether this can be done without the original classes. But I think there should be something like a generic reflection capability.
Maybe try to create a serialized object structure in .NET first, to see how the headers are formed (to see whether this matches the beginning of the file, or if there is anything else added).
I hate this edit window 😞 Can we please have a forum?
 I didn't realize it was a .Net application. Thanks for the info. Usually to deserialize an object you need the original class. Although you can try writing a smal net appplication to deserialize it and then serialize it into XML.
But, I doubt you will get enought info for a simulation. You will get better chance manualy writing your simumation data from the schematic.
lalec_300236
First like received
        you may need to ask Cypress to get the information about the contents of the file. I think it would be quicker to draw it with the package you use for simulation.
HeLi_263931
Level 8
Level 8
Actually from what I can see in the file one should be able to generate a complete netlist from the schematic. There seem to be objects for all the components, and for all the wires (even with names...).
The problem with the simulation is then more a problem of simulating the components.
 I understand that is not a simple thing to do. But, for now, i need to understand how PSoC Creator works with the schematic, even if i can't do what i want.
        Anyway, I know another example of schematic with simulator. That is Xilinx ISE. that's schematic is wrote by VHDL and that's simulator is working with this VHDL and VHDL for simulation. it might be help for your concern.
HeLi_263931
Level 8
Level 8
How does looking at Xilinx ISE schematic files help with how Creator stores its schematics?
Anyway, your best guess right now is looking to .NET serialization /deserialization. Google yields some interestings pages:
        "Anyway, your best guess right now is looking to .NET serialization /deserialization. Google yields some interestings pages:" That's what i'm going to do! Tks!
HeLi_263931
Level 8
Level 8
        If you find anything interesting, please report back here... I'm sure there will be people interested in your findings (I'm surely are)
Any update in my problem, I'll post it here.
Hi aamaral,
i have now nearly the same problem, i need to understand the formal of the *.cysch file und read it eternally(e.g. with text editor)
Did you find out how to do this?
ETRO_SSN583
Level 9
Level 9
File a CASE -
To create a technical case at Cypress -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
