PSoC™ Creator & Designer
I have installed PSoC Designer 5.0 SP6.When i tried to create a new chip level project i got the error message "Unsuccessful Access:Uninitialized Interconnect view". I tried with different devices then also got the same error.
A new window opened as message from webpage "ERROR:g_DEXDoc==null".
Another window opened titled "Internet Explore Script error" showing
An error has occured in the script of this page.
Line :3877
Char :2
Error :Object doesn't support this property or method
Code :0
URL:file:///C:/program%
              20Files/Cypress/Packages/ExpressEditor/CMXData/cmxgui.htm
I want to use the device CY8CPLC20(powerline communication)
MR_41
Reinstall Adobe SVG viewer from the adobe site and that should solve this problem.  Check out the below KB article.
                     http://www.cypress.com/?id=4&rID=27284
Ganesh
The PSoC Hacker
MR_41
Ganesh
The PSoC Hacker
Thank you Sir
Abdul Haseeb O P
