user_4289526
My question relies on the provided code generated through the widget components API. Does the code comply any kind of certification? If so, where are the documents which explain that certification?
Thanks in advance for the help!
DheerajK_81
There is no certification rather there is a process to be followed when creating the component API files. Please go to Help > Documentation > Component Author Guide in PSoC Creator. Refer to "Chapter 6: Adding API Files" for more information on this process.
Dheeraj
DheerajK_81
Dheeraj
