Hi All,
I am a newbie for this system. I have questions about digital GPIO write and read.
1. When I tried to copy code examples to my new project, it shows CY8C5888 and S6E1C3 not compatible and couldn't change to new chip
2. I tried to use port_name+write or port_name+read, but when I build the system it shows that "LCD_CS_write" is undefined.
LCD_CS is a gpio port name, while LCD_CS_write is a output command.
I hope to know how to define a GPIO output macro or function associated to a special PORT or BIT.
I use CY8CKIT-059 Prototyping Kits
Thank you in advance.
Jim
Please post your code so we can check it. Click on file and then Create workspace bundle. Then attach the file created to a new comment by clicking add attachments.
I listed associated pins below
Pin name and connections:
LCD_CLK ------->P2.5 LCD clock.
LCD_CS---------->P2.3 LCD chip selection
LCD_SEL---------->P2.4 LCD instruction and data selection
LCD_SI------------->P2.6 LCD data
Pin0_0--------------->P0.0 : waveDAC 1 outtput
Pin0_1--------------->P0.1 : waveDAC 2 output
Pin3_6--------------->P3.6 : waveDAC 3 output
Thanks again.
Jim
Jim, may I suggest you read again bobgoar post ?.
Tony
Hi Tony,
Thanks very much. Sorry, I solved problem.
How did you solve your Problem? Using "LCD_CS_Write" instead of "LCD_CS_write" ??
Bob
Yes, LCD_CS_Write is correct.
Jim
