From PSOC5 to PSOC4
Hi there,
I have a block diagram for PSOC5. Now, I want to transfer from PSOC5 to PSOC4. However, there are some errors which said incompatible for certain block. May I know how can I solved this? I am new with this PSOC software. Thank you very much.
Bob_Marlowe
Level 10
Level 10
Welcome in the forum.
There are some components available for PSoC5 that cannot be used for PSoC4 as the filter and the delta sigma adc. Usually there are in the PSoC4 adequate replacements. Those you need to use and change the APIs accordingly.
When you post your complete project, we all can have a look at all of your settings. To do so, use
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Hi Bob,
Thank you for your prompt reply. Yup, I have problems with delta sigma adc, dma, op-amp and also pga..the PSOC5 block diagram was given to me so that I can applied it to the PSOC4.
Affiq
Hi Bob,
Sorry for the late respond. I have attached the files with this post. Thank you.
Affiq
Bob_Marlowe
Level 10
Level 10
Your selected device has not got DMA. Usa a different PSoC4BLE
Replace the "not supported" components with existing ones. For the PGA you will need to use an opamp and some external resistors.
Bob
Thank you Bob. But what do you mean by using different PSoC4BLE?
Affiq
Bob_Marlowe
Level 10
Level 10
Your chip has got Bluetooth Low Energy (BLE) capabilities. When you do not need them, use a different family.
Bob
