CeGu_1509311
First like received
I'm trying to get first decimal from a float, however when I'm debigging the aplication it changes the actual value for exmaple:
float test = 5.1;
The debugger says that the value stored is 5.0999999, the same issue is happenning with
float test = 5.100001;
debugger says that test = 5.100004.
With this issue I can't get the fist decimal.
Any idea??
Bob_Marlowe
Level 10
Level 10
The difference you see has to do with the representation of floats as digital numbers, you will always get divergences between decimal and float representations.
What exactly do you need the first decimal for? When you want to display that number use sprintf()
You even may use
HelpInt = (int)(fabs(MyFloat) * 10.0);
Help2Int = HelpInt / 10;
Help2Int *= 10;
FirstDec = HelpInt - Help2Int;
Another way could be to add 0.05 to force rounding
See a discussion about round() here.
Happy coding
Bob
Bob_Marlowe
Level 10
Level 10
You even may use
Help2Int *= 10;
Happy coding
Bob
