Export PSoC Creator Project to Eclipse as C++ project
I found PSoC Creator 4.0 can compile C++ source.
But text editor of PSoC Creator doesn't support C++, so keyword highlight, auto complete doesn't work.
So, I exported project to eclipse, but I have trouble in setting up eclipse to compile C++.
First, I exported project as C project, at that time, compile was successful.
After that, I added C++ nature by "File > New > Convert to a C/C++ project".
I set include path of c++ compiler same as c compiler.
Then,  I built the project, but eclipse output some errors as following.
"undefined reference to `__cy_regions`" in Cm3Start.c
"undefined reference to `__cy_stack`" in Cm3Start.o
How to fix that?
AnkitaS_51
"_cy_regions " & "_cy_stack" are defined in linker script file(.ld),we do not recommend to convert to a C++ project.
AnkitaS_51
OK, Thanks ANKS.
