ShM_1238346
I am using PSoC 5.
I am trying to use "#pragma enumsalwaysint off" for selectively turning on/off the sign of the enums,
I using C99.
When I use the pragma and compile , I get the following message.
"warning: ignoring #pragma enumsalwaysint off [-Wunknown-pragmas]"
Why am I getting the warning? What is the best way to selectively turn on/off the sign of the enums?
AnkitaS_51
C99 is supported but "#pragma enumsalwaysint off" is not a part of the definition. You need to use header guards in such cases as mentioned in the thread linked below: #pragma once?
Dheeraj
AnkitaS_51
Dheeraj
