Emulated EEPROM with PSOC4
ReMa_3807036
First like received
I'm using PSoC Creator 4.3 with device PSOC4100S  CY8C4125AXI-S433, in my design I'm using Flash to emulate EEprom and I'm following the relative code example, and here I have a problem, the variable "Em_EEPROM_em_EepromStorage" within the generated file Em_EEPROM.c, is declarated only if defined "CY_PSOC6", and it is not here the case.
#if ((CY_PSOC6) && (Em_EEPROM_1_STORAGE_EM_EEPROM))
    CY_SECTION(".cy_em_eeprom") CY_ALIGN(CY_FLASH_SIZEOF_ROW)
    const uint8 Em_EEPROM_1_em_EepromStorage[Em_EEPROM_1_ACTUAL_SIZE] = {0u};
#endif /* ((CY_PSOC6) && (Em_EEPROM_1_STORAGE_EM_EEPROM)) */
Probably I'm wrong ... Have you any suggestions?
Renato
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear Renato-san,
Please READ the datasheet of Em_EEPROM.
In the page 2 it is written
Please read carefully after the line "For non-PSoC 6 devices,.."
19-May-2020
moto
