MaCa_301471
First like given Welcome!
It seems that the bug related to the presence of user folder breaking eclipse importer is still not fixed.
I managed to patch he issue by adding a couple of file filters "Resource Filters" menu to fetch project root source files.
Does anyone have different solution?
Are there plans to fix this issue in forthcoming updates.?
Marco
DheerajK_81
I have forwarded this query to the software development team. Thank you for your interest in Cypress products.
Your method works. Can you please tell me which version of Eclipse you are using and the target device?
Dheeraj
MaCa_301471
The target is a CY8C4245LQI
Eclipse IDE for C/C++ Developers
Version: 2019-12 (4.14.0)
Build id: 20191212-1212
PSoC Creator Import
Version 2.4.0
The ARM toolchain is the one bundled with PSOC Creator (in this case 4.3)
Marco
I have forwarded this query to the software development team who will process your request. I will update you on the developments.
Thank you for your interest in Cypress Products.
Dheeraj
