In Designer, 5.2, I use E2PROM module. If I leave module name as "E2PROM_1",
everything compiles OK. If I change it to "E2PROM", compile fails, because files
retain the _1 naming convention, even after doing a clean of project. I get missing
symbol errors, like E2PROM_Start()........compiler still wants it to be E2PROM_1_Start().
HiTech is compiler. Used because right up against code density, 32KB limit, Imagcraft
does not come close.
I normally rename modules this way as I have several designs only using one module,
need to make names as short as possible due to readability.
Regards, Dana.
Hi Dana,
is this still a problem you are dealing with?
I can understand that you are out of options using the High-Tech versus the Imagecraft compiler because of code densisty. As you know we do not have any access to High-Tech any more and the latest versions of Designers have been released with Imagecraft only.
Nevertheless, trying to get you an answer, hold tight.
Robert
I worked around it by giving it the name it wanted, rather than the one I wanted.
Regards, Dana.
