There is no constant defined for Shiftreg_RET_FIFO_NOT_FULL like shown on page 10
Bob
Thanks Bob,
forwarded your findings to the component documentation team.
Robert
Bob -
Thanks for pointing this out. You are correct the value that will be returned by the component is RET_FIFO_NOT_EMPTY. I'm not happy with the name of that define and I've asked to keep it for backwards compatibility, but to add and document this value as RET_FIFO_PARTIAL. This value does not mean that the FIFO is NOT_EMPTY or NOT_FULL. This value actually is returned when the FIFO is partially full (ie. neither FULL nor EMPTY).
Brad
This is one of the few places where a returned value is preponed by "RET_" . Why not call it just "FIFO_PARTIALLY_FULL" and rename the other defines similarly and according to other component which use a FIFO. That could be made system-wide.
Bob
