HuEl_264296
First like given 25 sign-ins First solution authored
Hi all,
Is it possible to insert a custom build step in Creator 2.0? We can do this is every other IDE (MPLAB, Visual Studio, Eclipse, etc.)
The reason we need to do this is to generate some header files using a python script before the main compilation happens. The has to happen every time I do a build, which is why we need to have it as an automatic part of the build process.
Is it possible? If not, I would like to request it as a feature.
Many thanks
Hugo Elias
HuEl_264296
 Any ideas?  Or can I make this a feature request?
